Results 1 to 2 of 2
    Default Bluetooth sync
    Do you know of a program for pc that syncs android calendar over bluetooth and does not need also to open the program on the phone? I don't want to sync in the cloud. Sync locally on the pc.
    By the way the Samsung Kies does not sync of calendar. There is not such a selection. How do i make it sync with calendar of the phone on the pc version of Samsung Kies over the pc?
  2. Best Answer
    Quote Originally Posted by marios1441 View Post
    Here's a app to sync outlook via bluetooth: https://play.google.com/store/apps/d....syncroid.lite
    There's another for Mac if that's what pc you are using.
  3. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Bluetooth sync
  1. Samsung Galaxy S4 master sync
    Last Post: 07-30-2016, 11:02 PM
  2. Stop Galaxy S5 from sending texts to Ford Sync
    Last Post: 06-27-2014, 11:53 PM
  3. Can't sync my Samsung Lite with Outlook
    Last Post: 06-17-2014, 08:31 AM
  4. Bluetooth Versions...What's The Difference?
    By Greg C in forum Samsung Galaxy S5
    Last Post: 06-17-2014, 06:45 AM
  5. Pop3 Email Stopped Syncing
    Last Post: 06-16-2014, 08:20 PM
