1. marios1441's Avatar
    Hello,
    I bought a bluetooth portable speaker for mobile phones and does not produce sound during calls (i can't hear the other person talking from the portable speaker). I only hear sound from multimedia and app sounds and voices. It is the Bassboomz bb-black bluetooth portable speaker. What should i do to make it work also during calls? Is it faulty or does
    it not support audio from calls? What other should i plug so i can hear the other person's voice during a call? Do other bluetooth portable speakers exist that plays audio also during a call from the mobile phone? If yes then do you suggest one and how much it costs?
    email:mariosgeorgiou@cablenet.com.cy
    06-17-2014 09:43 PM
  2. Mooncatt's Avatar
    I was under the impression Bluetooth speakers don't handle voice calls, but never checked first hand. If the manual doesn't say, check your phone's Bluetooth settings. In the phone's Bluetooth settings, you'll see the various devices paired to it (may need to make sure BT is turned on for that). Go into the settings for the speaker on the phone. You should see two options, one for phone and one for media audio. If the phone audio isn't checked, then check it and test it. If the phone audio option isn't even available, then the speaker isn't capable of handling calls.
    06-17-2014 10:20 PM
  1. Samsung S4Mini all contacts Bluetooth to Solara 2007
    Last Post: 06-29-2014, 01:42 AM
  2. no bluetooth connection on verizon samsung galaxy note 3
    Last Post: 06-29-2014, 12:09 AM
  3. Bluetooth share has stopped working
    By Kathy B in forum Motorola Droid Ultra
    Last Post: 06-17-2014, 08:46 PM
  4. external speaker vs cell-phone speaker
    By caj27 in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-17-2014, 02:04 PM
  5. Replies: 1
    Last Post: 06-17-2014, 08:21 AM
