Results 1 to 2 of 2
    Default Full screen direction
    When i play a video in Youtube or other video sites and i click the full screen icon does not go full screen vertical and only horizontally when i turn the phone to its side. Do you know of a app or a way to make the phone show full screen also vertically?
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: Full screen direction
    Youtube videos are wider than they are high (16X9 ratio of width to height), so you can't show them full screen on a screen that's higher than it is wide. It has nothing to do with the phone, it's mathematically impossible unless you stretch the picture out vertically. Then you get tall, thin people.
    When you hold the phone vertically, the picture takes up the full width of the screen, so it's shorter than the length. They could expand it to full screen, but they'd have to chop it off at the sides, so you'd see only about 1/3 of the picture horizontally.
  1. Only the exact centre part of touch screen is not working
    Last Post: 03-13-2015, 10:06 PM
  2. Samsung Galaxy Tab 3 - Lock Screen PIN
    Last Post: 07-06-2014, 10:18 AM
  3. Nexus 4 screen cuts off on the left
    Last Post: 06-26-2014, 11:22 AM
  4. Replies: 3
    Last Post: 06-19-2014, 05:23 PM
  5. Camera icon on lock screen
    By jjfan71 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 06-17-2014, 11:56 PM
