Hi Guys, I just rooted and installed CM11, no problems there. Then I restarted after a few hours of use and it got stuck on the samsung logo - I tried flashing CM a few more times, factory reset, full wipe, cleared cache still no joy.
I then flashed a stock rom through Odin and it still will not go past the samsung loading screen, the one which says 'samsung tab 3'
totally at a loss as to what to do - I have put a load of various roms, and SuperSU onto my miniSD and transferred them to my internal SD to try flashing them too but I have had no luck - it seems no matter what software I flash I get stuck at the samsung screen
