1. CannedBullets's Avatar
    https://play.google.com/store/apps/d...kcin.deskclock
    I'm trying to get the digital widget on my homescreen but I can't find it in the Widgets drawer. What's going on? Do I have to buy the paid version?
    06-19-2014 03:13 AM
  2. B. Diddy's Avatar
    What phone and Android version are you using? Are any of the Clock+ Widgets showing up in the Widget Drawer? Have you tried rebooting? On my old Razr Maxx (on 4.1.2), I often had to reboot before new widgets showed up.
    06-19-2014 06:08 PM
  3. CannedBullets's Avatar
    Yeah I figured it out, I was trying to do it on my Razr Mass (also at 4.1.2) and the digital widget only works on higher versions of android. I think 4.2+ or 4.3+.
    B. Diddy likes this.
    06-20-2014 02:03 AM
  1. Replies: 18
    Last Post: 06-29-2014, 12:50 AM
  2. Surah Yaseen Application For Smartphones
    By aatiqahnyla in forum General News & Discussion
    Last Post: 06-19-2014, 10:00 PM
  3. Replies: 1
  4. Replies: 1
    Last Post: 06-19-2014, 08:56 PM
  5. how much bloatware does LG G2 has pre-installed on?
    By snadvi in forum T-Mobile LG G2
    Last Post: 06-18-2014, 11:59 PM
