1. marios1441's Avatar
    My wifi SSID is not visible anymore. The room is in range.
    06-22-2014 07:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Start by rebooting the router. If that doesn't help, make sure your device isn't searching on the wrong band--i.e., if your device can operate on the 2.4 and 5 GHz bands, make sure it isn't set to look for only one band.
    See other tips here: [GUIDE] Troubleshooting Wi-Fi Connection Problems
    06-22-2014 08:53 PM
  3. Rukbat's Avatar
    Also make sure that no one disabled SSID broadcast in the router.
    B. Diddy likes this.
    06-26-2014 11:00 PM
  1. Wifi only Sprint Epic 4G Dying? Google Play not working.
    By daehttub in forum Samsung Epic 4G
    Last Post: 08-25-2014, 08:40 PM
  2. Have to manually connect to my home Wifi all of a sudden
    By Jon Jackson in forum Samsung Galaxy S5
    Last Post: 06-25-2014, 09:09 PM
  3. google 7 wifi connection problem
    Last Post: 06-22-2014, 04:56 PM
  4. Galaxy S5 WiFi Connection
    By jyounger6 in forum Samsung Galaxy S5
    Last Post: 06-22-2014, 01:49 PM
  5. Unanswered question on rooting 2012 nexus 7 wifi
    Last Post: 06-22-2014, 01:13 PM
