06-25-2014 12:33 AM
30 12
tools
  1. peacefulberry's Avatar
    I have a brand new Note II that I've only had for 3 days. On the 2nd day, I experienced considerable lag. Initially, I decided to return it, but some members suggested that I use Nova L. or Launcher Pro to make the phone faster. I liked the mosaic live photo wallpaper of the regular stock launcher...my question is does Nova or Launcher Pro have a live mosaic photo wallpaper? Do these launchers really make the phone faster? Please help me with one or both of the above questions...thanks for all of your help!
    06-23-2014 11:46 AM
  2. wizzrah's Avatar
    Hi!
    Nova Launcher is a launcher that imitates completely stock android. While it overlays on top of your phone, a lot of things will be unaffected, such as the ability to choose wallpapers. You can still use the live mosaic wallpaper. As for performance, it does help the phone in some way. The only real way for you to find out if it helps the phone is for you to actually try it out.
    https://play.google.com/store/apps/d...oilsw.launcher
  3. wizzrah's Avatar
    Hi!
    06-23-2014 11:49 AM
  4. peacefulberry's Avatar
    Hi!
    Does my phone have to be rooted? Also, will the Note II's capabilities, S pen, multi-tasking, etc. be affected?
    06-23-2014 12:22 PM
  5. wizzrah's Avatar
    The phone does not have to be rooted. You can access any apps as you want and use the S Pen as well. Again, it won't hurt to try it out for yourself!
    RumoredNow and peacefulberry like this.
    06-23-2014 12:23 PM
  6. RumoredNow's Avatar
    The App description does not mention root. It will not wipe your data or compromise functions.
    It's just a different look for the home screens(s) and App Drawer. It's what is known as "eye candy."
    wizzrah and peacefulberry like this.
    06-23-2014 12:27 PM
  7. peacefulberry's Avatar
    I will certainly give it a try...Would you suggest Nova L. or Launcher Pro for the fastest, cleanest experience? Thanks again!
    06-23-2014 12:39 PM
  8. RumoredNow's Avatar
    Try the free version first and see if you like it. Then go "Pro" if you decide to keep it.
    06-23-2014 12:42 PM
  9. peacefulberry's Avatar
    Thanks for your help!
    - - - Updated - - -
    Didn't realize there was a free version.... cool!
    RumoredNow likes this.
    06-23-2014 12:46 PM
  10. wizzrah's Avatar
    - - - Updated - - -
    The one I linked to was the free version!!!!!
    06-23-2014 12:52 PM
  11. Sergiusz Jasper's Avatar
    Works great on my moto g ...
    sent from Mars using Moto g !
    06-23-2014 12:54 PM
  12. peacefulberry's Avatar
    I just researched it, didn't click on the link yet. LOL! Thanks again!
    06-23-2014 12:54 PM
  13. peacefulberry's Avatar
    I forgot to ask if you like Nova better than Launcher Pro?
    06-23-2014 12:55 PM
  14. wizzrah's Avatar
    Nova Launcher. If you are referring to this Launcher Pro: https://play.google.com/store/apps/d....fede.launcher
    Please don't install it. It's over 3 years old and outdated. LauncherPro was last updated in 2011.
    peacefulberry likes this.
    06-23-2014 12:57 PM
  15. peacefulberry's Avatar
    Oh I see that...thanks for the heads up!
    06-23-2014 01:19 PM
  16. wizzrah's Avatar
    No problem. Come back to AndroidCentral if you run into any problems or have more questions.
    06-23-2014 01:20 PM
  17. Sergiusz Jasper's Avatar
    The one in play store shows June 6 2014 ...so it should be up to date .
    06-23-2014 01:31 PM
  18. wizzrah's Avatar
    That's for Nova Launcher. I was referring to LauncherPro: https://play.google.com/store/apps/d....fede.launcher
    It was a good launcher in it's prime, but not anymore.
    06-23-2014 01:34 PM
  19. peacefulberry's Avatar
    Thanks...1 more question: (I'm making a list of all the things I should do after returning from a hard reset.) I saw suggestions about turning off animations in the Dev Options...should I turn the 3 categories (animations and transitions) to NONE or 0.5 or leave it at the default 1?
    06-23-2014 01:51 PM
  20. wizzrah's Avatar
    Setting it to None will definitely reduce the load on the phone.
    06-23-2014 01:53 PM
  21. peacefulberry's Avatar
    Cool...that's what I did...I left GPU and max number of background tasks settings at the default levels...is that ok?
    06-23-2014 01:55 PM
  22. wizzrah's Avatar
    Yep.
    06-23-2014 02:30 PM
  23. Sergiusz Jasper's Avatar
    Is there anything better ...free?
    06-23-2014 03:00 PM
  24. peacefulberry's Avatar
    I think most of them have a free and a paid version so you can try which one that works.
    Anyone tried Apex Launcher...which one would be better in your opinion, NL or Apex?
    06-23-2014 03:40 PM
  25. wizzrah's Avatar
    Nova Launcher.
    - - - Updated - - -
    I think Go Launcher is pretty fun. https://play.google.com/store/apps/details?id=com.gau.go.launcherex
    06-23-2014 04:39 PM
  26. Sergiusz Jasper's Avatar
    Just tried go luncher its cool almost iPhone like experience problem is tho it does not transfer ur apps u have move all apps back and to much advertising ...back to nova
    06-23-2014 05:00 PM
30 12
  1. Replies: 2
    Last Post: 06-25-2014, 07:45 AM
  2. Google Maps Question
    By cb2367 in forum Motorola Droid MAXX
    Last Post: 06-24-2014, 05:27 AM
  3. Tab Pro 10.1-8.4 on sale at Best Buy 349.99-249.99
    By SAMmarked1 in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 06-23-2014, 11:19 AM
  4. Replies: 2
    Last Post: 06-22-2014, 09:24 PM
  5. Unlocked S5 question?
    By Jtshurtleff in forum Samsung Galaxy S5
    Last Post: 06-22-2014, 08:43 PM
