1. eddiebhoy's Avatar
    I have a few apps I use to maintain my phone for i.e , ccleaner , clean master du speed and all-in-one-toolbox which basicly just cleans up junk files and gives a boost to memory , but I have a app called defrag-Cache and it only allows me to use once a day , But would you say it is not safe or safe to use , ty.
    06-23-2014 05:24 PM
  2. B. Diddy's Avatar
    Is it this one? https://play.google.com/store/apps/d...=com.mdvs.apps. It looks like all it does is clear your app caches, the same way your other apps do. It just does so with some animation.
    It probably only allows you to clear the app caches once a day because doing it multiple times a day may actually be counterproductive. The caches are used by apps to store temporary data for quick retrieval (e.g., recently visited webpages on Chrome). It's true that if they become monstrously large, they can slow the system down. But if you constantly clear the app caches, apps might take a little bit longer to do what you want them to do.
    I would just stick with one of those apps.
    06-23-2014 05:56 PM
  3. eddiebhoy's Avatar
    what one would you stick with as , See the app you mentioned as in the once that defrags the cache with the link you put in that is the one I use , and it only allows you to do it like maybe twice at the most each day , so with me doing it every day is it harmful or is it ok.
    06-25-2014 03:19 PM
  4. B. Diddy's Avatar
    I'd probably stick with CleanMaster, which is one of the more popular apps. I used to use All-in-One Toolbox, but found that it actually used up quite a bit of RAM when running, so it was hard to really tell how the system was running.
    06-25-2014 06:11 PM
  5. Rukbat's Avatar
    I'd suggest only 2 things.
    1) Don't use apps that remove other apps from RAM. That's counterproductive - it actually makes Android's memory manager work worse.
    2) The memory in a phone (any solid state memory) has a finite number of write cycles. Clearing the cache when it doesn't need to be cleared (IOW, when the phone hasn't started to slow down) eats up some of those write cycles.) I actually find that my phone only needs a cache clearing every few months, at most. Most apps are good at cleaning up after themselves. As far as defragging, it takes as long to change to the address of the next memory byte as it takes to change to the address of a byte half-way across the memory space. Defragging makes a lot of sense with a hard drive running an OS like Windows. It doesn't make much sense with solid state memory. (And there have been hard drive operating systems that were inherently unfragmentable. Space-inefficient, but fast.)
    B. Diddy likes this.
    06-26-2014 10:17 PM
  1. Replies: 11
    Last Post: 03-17-2015, 07:20 AM
  2. wiped intrenal sd of my htc one sv
    Last Post: 09-01-2014, 08:57 AM
  3. Dropped Nexus 7 face down and experiencing "ghost" touches?
    By mineman1427 in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-24-2014, 06:29 PM
  4. How to delete auto save pictures
    Last Post: 06-23-2014, 06:31 PM
  5. Moto Stream Unboxing and Mini Review
    By dpham00 in forum General News & Discussion
    Last Post: 06-23-2014, 04:38 PM
