1. asdfmn's Avatar
    Good evening guys!
    I have a problem with my Neken N6 android smartphone.
    Every time I plug it to a PC, when I then select the option to unmount the internal SD card and mount it to the PC, the phone suddenly reboots.
    That wan't happening when I bought it, but I don't know which app is making the difference since the problem started.
    I've looked to the apps on the SD card and I don't imagine any of them crashing the phone because of a forced closing: none of them are system-related.
    Is there any way to see information about what makes the system crash? Any log, dump, etc?
    Thank you in advance!
    06-25-2014 03:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I've never encountered that option with any of my previous phones--you shouldn't have to unmount the internal SD card yourself. What kind of USB connection does your phone have? Is it MTP or "USB Mass Storage/Disk Drive"? To find out, after connecting your phone to your computer, swipe down the notifications and tap the USB connection notification. With my old Razr Maxx, plugging it into the computer would automatically mount the Internal SD (aka Internal Storage) as well as the External SD, as long as the connection was "USB Disk Drive." While plugged in, the phone would not be able to access either of these storage areas, since they were mounted to the computer.
    06-25-2014 07:20 PM
  3. asdfmn's Avatar
    Hi!
    It's mass storage, and that's exactly why the phone unmounts them from android and mounts them to to the computer.
    And while unmounting from Android the crash happens.
    06-26-2014 02:40 PM
  4. B. Diddy's Avatar
    That might be tough to troubleshoot. I'm not sure if there any log apps or debugging apps that could give you the kind of information you're looking for. You could always start uninstalling apps one by one and seeing when the problem resolves, but that's pretty tedious.
    06-27-2014 01:44 AM
  5. asdfmn's Avatar
    Yeah, hope someone comes with a less destructive solution xD
    06-27-2014 07:41 AM
  6. Rukbat's Avatar
    You could install Logcat or aLogcat and see if you spot anything in the logs.
    06-28-2014 12:52 PM
  7. asdfmn's Avatar
    What a shame, it showed nothing interesting! ...
    BTW, just to clarify, it happens when clicking that button:
    Phone reboots and after that, SIM configuration is lost
    07-01-2014 11:39 AM
  8. Moltres_rider's Avatar
    I have the same problem on my Samsung Galaxy s4
    02-24-2015 07:36 PM
  9. asdfmn's Avatar
    Hi Moltres_rider.
    Sorry for not posting back, I have forgot which forum I have asked about this.
    Finally in my situation it was this xposed module's fault:
    (google for xposed KitKat SD Card Full Access, I have no reputation to post links)
    03-01-2015 09:59 AM
  1. S3 mini SD card pictures - "no location 143"
    By Roy Gavilan in forum Ask a Question
    Last Post: 09-08-2014, 11:09 PM
  2. Missing videos from SD Card
    By gimmeyoshoez in forum Samsung Galaxy S4
    Last Post: 07-07-2014, 09:52 AM
  3. Supreme court ruling on cell phone searches
    By Mooncatt in forum Politics
    Last Post: 06-26-2014, 06:04 PM
  4. android apps working with kycera hydro c5170 phone
    Last Post: 06-25-2014, 09:08 PM
  5. Purple Mark when Screen is Black but on
    By kyoo in forum Google Nexus 5
    Last Post: 06-25-2014, 08:55 PM
