1. gnr_2's Avatar
    Hi all,
    I have a N7 2013 Wifi edition. It is rooted and I was doing a ROM update. I did a factory reset, flashed ROM and a minimal gapps package then wiped cache and all that. Rebooted, installed My Backup Pro to reinstall my apps from backup and it is saying that all 26 GB are full. I have about 9 apps that installed from the backup, the rest are system apps.
    What is going on? What should I do to fix this?
    TIA
    Sent from my "no longer 120° or battery guzzling" Sprint Galaxy Nexus, thanks to help from the AC forum
    06-25-2014 04:16 PM
  2. gnr_2's Avatar
    PS I started the process over and same thing. Like 250 MB free with no apps installed. When I'm in recovery it says internal storage is using 360 MB so I don't know where the disconnect is or how to fix it. Also my recent nandroid backup keeps failing when trying to restore so that's not an option either. 😥
    06-25-2014 05:02 PM
  3. gnr_2's Avatar
    Found answer over at XDA. Turns out it was the Nandroid backup files taking up all the space.
    Sent from my Nexus 7 using AC Forums mobile app
    06-26-2014 02:36 AM
  1. Help! Droid Ultra on straight talk
    By darksylum in forum Ask a Question
    Last Post: 10-30-2014, 03:26 PM
  2. Bottle cap Game - useless but addicting
    By skywalker339 in forum Android Games
    Last Post: 06-25-2014, 09:04 PM
  3. Purple Mark when Screen is Black but on
    By kyoo in forum Google Nexus 5
    Last Post: 06-25-2014, 08:55 PM
  4. Please help!!!!!!!!!!!!!!!!!!!!!!!
    By iOstodroid79 in forum Ask a Question
    Last Post: 06-25-2014, 05:19 PM
