1. jamak's Avatar
    I have a Samsung Galaxy Ring from Virgin, my first smartphone. I'm catching on slowly for most things but can't figure out how to clear old phone calls in one move rather than having to delete 40 or so one at a time. Manual is pretty useless.
    My phone uses Version 4.1.2, if that helps.
    06-26-2014 10:38 AM
  2. raptir's Avatar
    I'm not sure about that phone in particular, but typically you go to the recent calls page then tap the menu button. There should be a "clear call log" option or something to that effect.
    06-26-2014 11:05 AM
  1. Replies: 14
    Last Post: 03-18-2015, 06:41 AM
  2. Help! Phone Not Displaying Texts on Lock Screen
    By BBBoldismyDRUGofChoice in forum Ask a Question
    Last Post: 09-06-2014, 10:33 PM
  3. Replies: 1
    Last Post: 07-09-2014, 04:40 AM
  4. How do I upgrade my nexus 5 android version.
    By fred5 in forum Google Nexus 5
    Last Post: 06-26-2014, 08:30 PM
  5. Is it possible to get "Android L" on the Galaxy S5?
    By PsychDoc in forum Samsung Galaxy S5
    Last Post: 06-26-2014, 07:32 PM
