1. marios1441's Avatar
    How do i restore the original wallpaper of the phone Samsung Galaxy Neo i9060?
    There is not in the default wallpaper list.
    06-26-2014 10:22 PM
  2. Rukbat's Avatar
    That looks like the standard Samsung blue wallpaper with a weather widget on it. (If you go to the next screen and the clouds aren't there, the clouds are part of the widget, not the wallpaper.) Open any graphics editor (I use Paint.net - it''s pretty good and it's free). Create a new picture, 480X800, and adjust the color to that shade of blue. Save it as a jpg or png file. copy it to the phone. Use it as your wallpaper. Or try Download wallpapers to your cell phone - blue galaxy gnote - 110005078 | Zedge Or look for wallpapers on Zedge - there are plenty of them. (Install the Zedge app. Search for Samsung and you'll get 729 wallpapers (at this time). Tap on one you like and you can download it right in the app. Then set it as your wallpaper.
    06-29-2014 04:40 PM
  3. marios1441's Avatar
    It is a blue sky and a sea with a splash in the middle of the sea in this model the default wallpaper i'm looking for.
    06-29-2014 07:02 PM
  4. Rukbat's Avatar
    Maybe the third one in Best Samsung Official Galaxy Note 3 Wallpaper HD Or the 7th one?
    06-30-2014 12:57 PM
  5. marios1441's Avatar
    No. Is none of those wallpapers you send me.
    06-30-2014 02:04 PM
  1. Replies: 2
    Last Post: 08-04-2015, 05:40 PM
  2. Change default opening of Phone app on Samsung s5
    Last Post: 09-29-2014, 04:46 PM
  3. Wallpapers and widgets seen in promo shots?
    By mpayne2k in forum Samsung Galaxy Tab S 8.4
    Last Post: 09-02-2014, 08:31 PM
  4. application cannot be installed in the default install location
    By Unregistered in forum Ask a Question
    Last Post: 09-01-2014, 01:23 AM
  5. Wallpaper
    By clintw22 in forum Samsung Galaxy S5
    Last Post: 06-26-2014, 07:20 PM
