What does "unfortunately, the process android.process.acore has stopped" mean?
A
AC Question
Android the process android.process.acore has stopped
Has anyone actually figured out how to fix this???
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Re: Android the process android.process.acore has stopped
What device are you using? I would recommend rebooting into recovery and clearing the system cache.
A
AC Question
What does "unfortunately, the process android.process.acore has stopped" means?
STARGATE
Ambassador
Oct 8, 2012
6,660
62
48
I'm not sure which one and I only recalled that happening to me once a long time ago with a Motorola Photon 4G.
I pressed OK and pulled the battery out, then placed the battery back on and restarted the phone. I never had that problem again.
Without more info is hard to know what exactly happened to your device.
Sent From Another Galaxy
A
AC Question
vern
i get the messsge android.process.acore has stopped when i try to acess the phone log or contact list any idea how i can that restarted.
Aaron Scowden
Well I read all these replies and didn't want to do it that way and lose any data to where I had to put it all back again. So with my android LG 3.0 I went to my contacts Icon and it would let me in groups but not contacts. I noticed that in the phone group section that some contacts was in one group and rest of the contacts was in the group "all other contacts" Well I deleted the one out of the one groups and reput them in my contact to where they was in "all other contacts" and that fixed the problem you all are Welcome
apkmodyo
