1. AC Question's Avatar
    Has anyone actually figured out how to fix this???
    06-21-2014 10:36 AM
  2. Golfdriver97's Avatar
    What device are you using? I would recommend rebooting into recovery and clearing the system cache.
    06-21-2014 10:58 AM
  3. AC Question's Avatar
    What does "unfortunately, the process android.process.acore has stopped" means?
    06-28-2014 10:57 AM
  4. STARGATE's Avatar
    I'm not sure which one and I only recalled that happening to me once a long time ago with a Motorola Photon 4G.
    I pressed OK and pulled the battery out, then placed the battery back on and restarted the phone. I never had that problem again.
    Without more info is hard to know what exactly happened to your device.
    Sent From Another Galaxy
    06-28-2014 11:08 AM
  5. AC Question's Avatar
    i get the messsge android.process.acore has stopped when i try to acess the phone log or contact list any idea how i can that restarted.
    06-29-2014 01:54 PM
  6. Aaron Scowden's Avatar
    Well I read all these replies and didn't want to do it that way and lose any data to where I had to put it all back again. So with my android LG 3.0 I went to my contacts Icon and it would let me in groups but not contacts. I noticed that in the phone group section that some contacts was in one group and rest of the contacts was in the group "all other contacts" Well I deleted the one out of the one groups and reput them in my contact to where they was in "all other contacts" and that fixed the problem you all are Welcome
    11-09-2014 09:51 PM
  1. customization of pjusa2 library in android application
    Last Post: 07-09-2014, 08:15 PM
  2. Question about the gallery
    By MBM7881 in forum Samsung Galaxy S5
    Last Post: 06-30-2014, 08:22 PM
  3. How will Sense on Android L Look and feel?
    By Thb91 in forum HTC One M8
    Last Post: 06-28-2014, 04:26 PM
  4. Exiting Navigation for Maps on the Samsung Galaxy S3
    Last Post: 06-28-2014, 11:10 AM
  5. Android devices with device-based (hardware) encryption
    By ozaz in forum General News & Discussion
    Last Post: 06-28-2014, 10:41 AM
