Results 1 to 8 of 8
    johnnie 65's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default galaxy s3
    Why wouldnt my sg3 connect to internet I git wifi but no internet apn settings are correct according to my carrier . Have been looking for a answer all over no success . I think I will throw it away . If you dont know why
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,765 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: galaxy s3
    First, can you confirm that your mobile data is turned on?
    Second, does your phone even detect the mobile data network? Do you see 3G or 4G displayed in the Notification Bar?
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Or do you mean that you can connect to wifi, but can't get an internet connection with wifi? (In which case, the APN and mobile data have nothing to do with it.)
    johnnie 65's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yes it shows 4 g in notification bar but doesnt connect
    johnnie 65's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    It detects it but doesnt connect when I try a message comes on saying no mobile network
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    You're mixing two things here. Are we talking about connecting to the carrier's network with 4G or are we talking about getting an internet connection with wifi. These are two TOTALLY DIFFERENT things. The wifi has nothing to do with 4G or your carrier, it connects to YOUR wifi router and if you get a limited connection (connect but no internet) we troubleshoot it one way, if you don't get an internet connection on 4G, we troubleshoot it in a completely different way. It's like your car not starting so you check the air pressure in the tires - one has nothing to do with the other.
    Turn off the part that works, If you're having trouble with wifi, turn off mobile data (Connections/More networks/Mobile networks) If you have trouble with 4G, turn off wifi. Then we can start trougleshooting to find out why you're not getting an internet connection.
    johnnie 65's Avatar
    Posts
    Global Posts
    31 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am not gitting a 4G internet connection but 4g shows up in notification bar . Am gitting wifi when mobile data is off
  8. #8
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    If you'rew not getting an internet connection in 4G, the most likely cause is that your APN settings are wrong. The settings depend on the carrier, so search for yours - like "Verizon APN settings". Or take the phone to the carrier's store and ask them to check the settings for you.
    If you have the correct settings and still don't get an internet connection, the most likely problem is that your account is set up incorrectly. You can either call customer support or, preferably, go to the carrier's store. (Then, if reprovisioning your account doesn't fix the problem, they have your phone and can do whatever is necessary to get it working, whether it's your account, your SIM card or your phone settings.)
  1. Home button wake up on Galaxy S5
    By glasblowa in forum Ask a Question
    Last Post: 06-28-2014, 08:10 PM
  2. Constant Reboot on Samsung Galaxy S3
    Last Post: 06-28-2014, 07:13 PM
  3. Replies: 1
    Last Post: 06-28-2014, 05:18 PM
  4. GoPro videos on Galaxy Note 10.1
    Last Post: 06-28-2014, 05:04 PM
  5. lost my galaxy note 10.1
    By Ken Brown3 in forum Ask a Question
    Last Post: 06-28-2014, 01:43 PM
