Results 1 to 3 of 3
    pollensa1946's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How come GMail contacts auto-added to Contacts?
    Moto G - stock Android.
    When I receive/send an email from my GMail a/c from/to a contact not in my Contacts/People list it gets auto-added to the list, filed under their GMail a/c addr. I go into Contacts and there it is, with no action on my part. I delete these and would prefer that it did not happen, but cannot find a setting that causes this.
  2. Best Answer
    Posts
    Global Posts
    579 Global Posts
    This is actually a function of your Gmail account, not Android. By default, Gmail adds everyone you e-mail to the Other Contacts list so that it will then autocomplete their e-mail address next time. You can disable this by going to your gmail account on a computer, navigating to the General tab in Settings, and disabling Create contacts for autocomplete.
    You can also go to your contacts app and select the lists to show and uncheck Other Contacts if you would like the Gmail behavior to remain the same.
  3. #2
    raptir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: GMail contacts auto-added to Contacts.
  4. Thread Author  Thread Author    #3
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK found it in GMail settings in PC Chrome. Thanks.
  1. How to lock text msgs from being deleted on Galaxy S5?
    By Christopher David3 in forum Samsung Galaxy S5
    Last Post: 07-25-2015, 01:12 AM
  2. Is it safe to delete the Galaxy S5 stock messaging app?
    By gotohealth in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 02-28-2015, 08:03 AM
  3. Replies: 6
    Last Post: 09-19-2014, 10:32 AM
  4. What are some alternative phones to the Note 4 to consider?
    By mothershipload in forum Samsung Galaxy Note 4
    Last Post: 09-19-2014, 08:05 AM
  5. Go SMS lost speech to text ability
    By paradroid in forum Samsung Galaxy S3
    Last Post: 09-18-2014, 03:44 PM
