1. SlappyMcgee's Avatar
    I think I might have figured out how to get it. I didn't have it yet, so I searched on my phone for "OK Google lock screen"and found this link.
    https://support.google.com/websearch.../6031948?hl=en After visiting the link on my phone, I went back into the Google Now Voice settings and had the extra "OK Google" detection settings.
    I have an AT&T SGS3. I hope this helps others
    Edit: 7/10/14 updated the link
    TeritorialDemon likes this.
    07-03-2014 06:29 AM
  2. sting7k's Avatar
    You can also buy a Moto X and have system wide "OK Google" commands; including when locked.
    07-03-2014 07:05 AM
  3. SlappyMcgee's Avatar
    That is not the point of this thread I was offering assistance to those, like me until yesterday, sat waiting and wondering when the options for system wide OK Google, including lock screen, would become available.
    But thank you for the advice
    07-03-2014 07:31 AM
  4. TeritorialDemon's Avatar
    THANKYOU for this. Worked on my Droid Razr M! I have been waiting for google to update this so I could use OK Google Now from any screen.
    07-08-2014 05:49 AM
  5. SlappyMcgee's Avatar
    You are welcome Glad I was able to help
    07-08-2014 09:21 AM
  6. Fr0gburp3r's Avatar
    That link doesn't take me to anything of significance. I have an AT&T SGS4 but I can't find the "OK Google" settings anywhere. It's stock.
    07-08-2014 07:22 PM
  7. SlappyMcgee's Avatar
    They seem to have moved the support article. Here is an updated link - https://support.google.com/websearch.../6031948?hl=en
    Fr0gburp3r likes this.
    07-10-2014 10:08 AM
  8. Fr0gburp3r's Avatar
    Thanks! I finally got it to work.
    07-10-2014 12:03 PM
  9. abdojouma's Avatar
    Great !
    Sent from my GT-I9505 using AC Forums mobile app
    07-10-2014 06:05 PM
  10. srkmagnus's Avatar
    Go to Google Now - menu. There will be an option for Google Now. That's where you can find the settings.
    Be sure to have the most updated Search app and do the search from within the Google Search bar.
    07-10-2014 09:51 PM
  1. Can't link Twitter to Instagram
    By liezette in forum Samsung Galaxy Note 2
    Last Post: 01-09-2017, 05:46 PM
  2. Replies: 1
    Last Post: 10-27-2014, 03:40 PM
  3. Replies: 1
    Last Post: 09-01-2014, 07:45 PM
  4. Can't login to Google from my phone.
    Last Post: 07-03-2014, 06:56 AM
