Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By anon8380037
    AC Question
    AC Question's Avatar
    Guest
    Default Where are my photos stored?
    I want to try and upload my photos to my computer, but I cannot find where they are stored. They aren't stored on my SD Card (although I would prefer it to so). A folder has automatically been created called "DCIM" > "Camera" but none of my photos store there. I tried using the ES File Explorer to search for them, but I cannot seem to get anywhere. They are obviously on my internal memory somewhere otherwise it wouldn't let me preview them. So, where could they be and how can set default save location to my SD Card?
  2. Best Answer
    There is a DCIM folder in Device storage and one in card storage, if you are connecting via usb without Kies your pc should see 2 drives. Try DCIM in Device storage.
    You can set the camera settings to save to sd card.
  3. #2
    anon8380037's Avatar
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Where are my photos stored?
  4. #3
    FoSizzle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is the problem. When I enable mass USB storage to my computer, only my SD Card is displayed and not my internal memory. I am also unable to find another DCIM folder in my internal memory (device storage).
  5. #4
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I cable my Samsung Note 3 to my W7 pc without 'enabling mass storage' on the phone screen, it will eventually see 2 drives.
    What phone do you have and someone may know?
  6. #5
    FoSizzle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a phone that works similar to the HTC, but it isn't a common brand of any sort - it is most likely just the phone. The phone is a BML One Mini.
  7. #6
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I bring up 'details' on a single photo it shows me the storage path.
  8. #7
    FoSizzle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I view details, it states "Album: Camera"?
  9. #8
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hmm. Don't know then.
    You tried hooking your phone with the sd card out and see if it will read the device then?
    There is probably another app that can find it.
    More help needed - - - - -
    Sent from my SM-N9005 using Tapatalk Pro
  10. #9
    FoSizzle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have done so much Googling and I don't have a satisfying answer. Thanks for the help on this though.
    Would it be wise to re-post this in another section?
  11. #10
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Definitely.
    This is a new Q+A forum, but its busy this Sunday .
    Please try and say hello as a new member in Introductions, which is under Android Central Community. Put your question there and very experienced moderators can put you right.
    Welcome to Android Central.
    Golfdriver97 likes this.
  1. Moto x AT&T how to have it go thru my Bluetooth in my car
    Last Post: 03-31-2015, 01:48 PM
  2. Replies: 3
    Last Post: 07-17-2014, 03:24 AM
  3. I'm still running Android Jelly Bean 4.3 on my Note 10.1 2014...
    By Diamant Belallari in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-11-2014, 08:30 AM
  4. Blue dots! On all my photos! Galaxy S3...
    By Katie Huitt in forum Ask a Question
    Last Post: 07-10-2014, 07:16 AM
  5. Advertisements being saved into photos??? (HTC One M8)
    Last Post: 07-06-2014, 12:11 PM
