Why android is using "Just Once/Always" as BUTTONS??! Logically they should be one simple CHECKBOX!
I like android, but it's crazy and a shame for android operating system for putting two buttons for "Always/Just Once" options instead of putting a simple checkbox with default unchecked value of "Always use same application"!
The checkbox can help to protect another extra click on "Just Once" button when you prefer to choose between different applications every time.
Please understand that extra click and "Just Once" button is not really necessary and it sucks when you every time select "Just Once"!
Please some android developers take care and fix this problem for later versions!
