1. moji_vb's Avatar
    I like android, but it's crazy and a shame for android operating system for putting two buttons for "Always/Just Once" options instead of putting a simple checkbox with default unchecked value of "Always use same application"!
    The checkbox can help to protect another extra click on "Just Once" button when you prefer to choose between different applications every time.
    Please understand that extra click and "Just Once" button is not really necessary and it sucks when you every time select "Just Once"!
    Please some android developers take care and fix this problem for later versions!
    07-07-2014 01:51 AM
  2. Almeuit's Avatar
    It is necessary for some. I may be testing a few apps... So I click on a link and try each one by hitting just once...that way I can test the various apps.
    Once I find the one I want I hit always and that way it will use the app I like.. Always.. For that type of link or information (such as my links always open Chrome).
    Remember just because you don't like it doesn't mean others aren't finding uses for it. Set your stuff to always and don't worry about it anymore .
    Sent from my T-Mobile Note 3 using AC Forums.
  3. Almeuit's Avatar
    07-07-2014 10:11 AM
  4. Golfdriver97's Avatar
    I have gotten in the habit of clicking just once for many things: Biggest reason is sometimes app developers don't code the app correctly. Sometimes, I want to use one app over another. Perfect example is when searching for apps online, I don't always want it to open via Play. I want to see it on Chrome.
    The only app I ever click always for is Nova over the stock launcher. This also kind of helps me greatly if I ever need to clear app preferences to clear out Play issues, I only have one thing set to default.
    07-07-2014 10:16 AM
  1. The Prime Is Now Available...
    By RaiderWill in forum Samsung Galaxy S5
    Last Post: 07-13-2014, 02:16 AM
  2. is the us celluar s3 supposed to be on 4.4?
    By 0pk in forum Samsung Galaxy S3
    Last Post: 07-09-2014, 02:47 PM
  3. Why does anyone buy damaged Androids?
    By JnEricsonx in forum General News & Discussion
    Last Post: 07-08-2014, 11:26 PM
  4. Android 2.3.6 vibrate on file selection
    Last Post: 07-07-2014, 06:01 AM
  5. Trying to run Miracast on Android x86 platform
    By Pankaj Baranwal in forum Ask a Question
    Last Post: 07-07-2014, 01:10 AM
