1. bulldogs195461's Avatar
    whats the easiest way to transfer my contacts,phone numbers etc from my samsung 4 phone to my sony xperia tablet,im looking to see how,but cant work it out
    regards john
    07-08-2014 04:35 AM
  2. pollensa1946's Avatar
    I use PC Chrome. I maintain all my contacts on PC Chrome and then sync account between phone(s) and PC.
    07-08-2014 07:49 AM
  3. VDub2174's Avatar
    You can also use something like Smart Switch. It transfers everything wirelessly.
    07-08-2014 08:40 AM
  4. B. Diddy's Avatar
    Are all of those contacts associated with your Google account or with the Phone Account? If they're associated with your Google account, they will sync automatically once you log in with your tablet. This is why I always recommend against entering contacts into the Phone Account--it's not as easy to move them to a new device.
    07-08-2014 12:26 PM
  5. Rukbat's Avatar
    If they're not Google account contacts, export them as a csv file. Then go to https://www.google.com/contacts/#contacts click More and Import the csv file you created. Then they'll all be Google account contacts. (You can also create vcf files when you export, but you have to import them one at a time, and if you have more than a few contacts, that's a lot of work.)
    07-08-2014 12:33 PM
  6. B. Diddy's Avatar
    I always get confused a little about CSV vs VCF files. I think I've been able to export contacts as a "multiple VCF" file, and import them as such, which fortunately makes it less of a hassle. But I can't recall the exact details at this moment.
    07-08-2014 12:40 PM
  1. contact birthdays showing up in calendar
    Last Post: 03-31-2015, 12:39 PM
  2. LG Optimus F3: com.android.contacts error code.
    Last Post: 11-26-2014, 04:24 AM
  3. KitKat update: GS3 contact list just a list w/o images
    Last Post: 08-07-2014, 03:34 PM
  4. How do I delete contacts from my Samsung Galaxy Centura?
    Last Post: 07-07-2014, 07:53 PM
  5. Contact management - could it be any dumber?
    By FBA in forum Samsung Galaxy Note 3
    Last Post: 07-06-2014, 11:51 PM
