Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By B. Diddy
  • 1 Post By Rukbat
    AC Question
    AC Question's Avatar
    Guest
    Default how to remove android trojan smssend.ty from my mobile
    I have tried to remove the trojan smssend.ty by malwarebytes, AVG, 360 security, Avast and all of these have failed. I have a prepaid mobile and it continues to nibble due to this trojan.
    Need help, please send your guiding advice [email removed by Moderator]
  2. Best Answer
    Welcome to Android Central! That's a bummer. You might have to do a factory data reset. Before you do that, go to Settings>Backup & reset, and make sure "Backup my data" and "Automatic restore" are unchecked​, so that whatever might have installed before doesn't automatically install again.
  3. #2
    Default Re: how to remove android trojan smssend.ty from my mobile
    Golfdriver97 likes this.
  4. #3
    Hi there
    I have similar problem but automatic restore option is ticked but faded out so i cant untick it. Is there another way i can do it or is it the trojans evil work?
  5. #4
    Rukbat's Avatar
    Posts
    Carrier
    Modified Stock 4.4.2
    Some Trojans even go so far as to redirect your attempt to install an antivirus program, so you can't even do that. A ROM reflash will kill anything, though as long as you power off, then boot into download from a power off state. (It's the equivalent of getting rid of a Windows virus by reformatting the drive in a Linux computer. To Linux, the virus is just some file - it can't actually run. To the download partition, the Trojan is ... somewhere, but not in that partition. It's as dangerous to your phone as it would be if it were in my phone.
    EdnaCubbard likes this.
  1. Android 4.4.4 AOSP Based d2lte Nightlies
    By The_Ab5trakt in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 05-03-2015, 02:18 PM
  2. expert help needed for non standard Android question
    Last Post: 07-11-2014, 12:50 PM
  3. mobile number
    Last Post: 07-11-2014, 09:42 AM
  4. mobile application
    By Unregistered in forum Ask a Question
    Last Post: 07-11-2014, 09:41 AM
  5. anyway to fix touch recognition issues?
    By RavenSword in forum Google Nexus 7 Tablet (2013)
    Last Post: 07-11-2014, 08:51 AM
