1. lbennet1's Avatar
    Every time I hit the home button, the screen pops up asking if I want to use "TouchWiz Easy Home" or "TouchWiz Home." I select TouchWiz and another popup explains the path to settings if I change my mind. That wouldn't be a problem once, but every time? Annoying! Any ideas, folks?
    07-12-2014 08:36 AM
  2. dpham00's Avatar
    Click the "always" button.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  3. dpham00's Avatar
    07-12-2014 08:39 AM
  4. lbennet1's Avatar
    Forgot to say, Samsung S5
    07-12-2014 08:40 AM
  5. lbennet1's Avatar
    I do, but 30 seconds later when I hit hime, same process starts again. Hitting always doesn't help longer than 1 mins (max) between hitting hime button.
    07-12-2014 08:42 AM
  6. lbennet1's Avatar
    Sorry for typos. Very frustrated right now.
    07-12-2014 08:43 AM
  7. dpham00's Avatar
    Go to the application manager and clear cache on touchwiz and easy touch wiz.
    Also try to clear cache in recovery
    07-12-2014 09:21 AM
  8. lbennet1's Avatar
    Cleared cache in Applications -》Application Manager -》All. Unfortunately, I also "forced stop." Didn't realize this would reset the whole deal. Now my organized apps are all back to default.
    One, can this be reversed?
    Two, not sure how to clear cache in recovery? Would someone mind to provide a pathway?
    Three, can the TouchWiz apps be deleted, as to just eliminate the issue? If so, what replacement is recommended?
    Thanks again!
    07-12-2014 10:53 AM
  9. dpham00's Avatar
    Thanks again!
    Sorry, didn't realize that clearing cache could cause it to reset the layout. I don't believe that there is a way to get it back.
    To clear cache in recovery, turn the phone off, then simultaneously press the power, home, and volume up button until the blue text appears. Then use the volume keys to scroll down to clear cache and use the power button to execute. When done, press the power button again to restart.
    You would need root to disable touchwiz.
    You can also clear all app preferences in the application manager.
    07-12-2014 02:04 PM
  10. Evilnut's Avatar
    I use Nova Launder Pro on all my devices. Smooth as silk & highly customizable. Plus gives me consistency on all my devices. My daughter installed it on her SGS4 & loves it. Give the free version a try. At least you will be able to tell if the issue you are having still happens with a 3rd party launcher too.
    Posted via a beautiful Ebony backed Moto X or the amazing Nexus 10 using the totally awesome Android Central App
    07-12-2014 02:38 PM
  11. lbennet1's Avatar
    Thanks for your help, folks.
    So, installed NOVA. Only change is it is now the third option when the window pops up after hitting home button. TouchWiz Home, TouchWiz Easy Home or NOVA Launcher are the three options given now.
    Regardless of which of the three are selected, always is selected, the next window is the pathway on how to change the setting in settings.
    If I knew how to post screenshots I would, as I have captured them.
    Any other thoughts for fixing this VERY annoying problem would be MUCH appreciated!
    P. S. Verizon swapped out my S5 and as soon as I logged in and the new phone recognized my profile, the EXACT same issue occurred.
    Thanks again!
    07-13-2014 08:13 AM
  1. Need help rooting Envizen tablet
    Last Post: 04-23-2015, 03:46 PM
  2. Help wont move my pictures and music!
    By katbolam13 in forum Ask a Question
    Last Post: 07-12-2014, 10:08 AM
  3. please help
    Last Post: 07-12-2014, 03:26 AM
  4. Can anyone help me root my Galaxy S Duos?
    By Unregistered in forum Samsung Galaxy S
    Last Post: 07-12-2014, 12:11 AM
  5. Replies: 1
    Last Post: 07-11-2014, 10:18 PM
