Results 1 to 4 of 4
    AC Question
    AC Question's Avatar
    Guest
    Question Swype Won't Work!
    Even though Swype is checked under Settings/My Device/Input and Control/Language and Input, it won't work while composing text.
  2. Best Answer
    Quote Originally Posted by Melanie Jackson1 View Post
    When I looked to change my keyboard "Keyboards and Input Methods" (please bear with me, I'm a novice) , Samsung or Swype are the only two available. I don't like the look of the Swype keyboard, so I choose the Samsung, which was my default and has always worked well and had Swype. Do you have any other suggestions?
    Google does have a keyboard available. You download it from Play and install it like a regular app. To have that be your default, you go back to the same screen that you described.
    Signed, an M8, Liquidsmooth, and the AC Forums App
  3. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,082 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Swype Won't Work!
    Quote Originally Posted by AC Question View Post
    Try a different keyboard. Google has a swiping form of typing.
  4. #3
    Melanie Jackson1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  5. #4
    Posts
    Global Posts
    33,082 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
  1. Replies: 8
    Last Post: 08-04-2014, 05:05 PM
  2. Voice guidance not working with Google Map
    By Axr6 in forum Verizon Samsung Galaxy S4
    Last Post: 07-13-2014, 11:15 AM
  3. Brand new galaxy ace - google play not working
    By TheJosieB in forum Ask a Question
    Last Post: 07-13-2014, 08:59 AM
  4. Cant use speech to text on my keyboard. It does not work.
    By AnimalMotherASF in forum HTC One M8
    Last Post: 07-13-2014, 03:28 AM
  5. Amazon bar code scanner won't focus.
    By SIOP in forum Samsung Galaxy S5
    Last Post: 07-13-2014, 02:42 AM
