Why isn't my Micro SD Card mounting and the formatting is not working?
A
AC Question
Micro SD Card not mounting, formatting not working
So far I have tried formatting through my android phone (says card damaged), through Windows UI (can't format), through Disk Management, and through SDFormatter. Nothing has worked. Chkdsk has returned that it is a raw file system and can't be formatted. TestDisk returns that there are no partitions. Any other suggestions of how I can reformat my card back to normal?
jmagid51
1,130
Re: Micro SD Card not mounting, formatting not working
It may be damaged. Take it back or return it. Sounds like you have gone through all the steps.
Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
kerokekerol
