1. AC Question's Avatar
    How do I add a contact on my Samsung Galaxy Centura phone?
    07-15-2014 06:05 AM
  2. Madd54's Avatar
    Hello.
    This works on most Samsung phones. Open Contacts with the icon.
    Make sure Contacts is highlighted on the right of phone, groups, favourites, Contacts.
    Below is a search window and to it's right a + box. Touch that enter your details and remember to save.
    You will have a choice of where to save with a drop down box. It's normally set to Device (phone), but you can save to sim card (limited space) or your Google or Samsung account. If you save it to device, you can sync or merge contacts with your accounts later.
  3. anon8380037's Avatar
    Hello.
    07-15-2014 06:36 AM
  1. Replies: 4
    Last Post: 07-25-2014, 01:19 AM
  2. Spilled alcohol on Samsung s4 3 days ago, any chance of survival?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 07-15-2014, 08:30 AM
  3. Turn off quick camera access on HTC One M8
    Last Post: 07-15-2014, 07:23 AM
  4. I have small problem with my s3...
    By RAvEcREAToR23 in forum Samsung Galaxy S3
    Last Post: 07-15-2014, 07:06 AM
