1. lowvpro's Avatar
    My 10.1 Tablet will only receive sync information from when I enter something on my PC or phone into my Google calendar, I have erased my Google account from the tablet and reestablished it, still nothing. I have sync enabled, it just won't send anything when it syncs will only receive.
    I've been trying to fix this for days, even talked to Samsung a few times.
    Any ideas before I try a reset to default?
    Please Obi-Wan you're my only hope.
    07-16-2014 07:50 AM
  2. lowvpro's Avatar
    And Nevermind, found it.... Apparently they added a drop down I hadn't noticed where you can enter things into "your calendar" or pull the drop-down and select your goggle account... Seems like if you select it to sync it should sync either way I MO.
    07-16-2014 08:01 AM
  1. Samsun Galaxy Note 10.1 Email address cache
    Last Post: 03-31-2015, 02:07 AM
  2. samsung S 5
    Last Post: 07-16-2014, 09:21 AM
  3. Replies: 1
    Last Post: 07-16-2014, 08:24 AM
  4. htc one wont power on
    Last Post: 07-16-2014, 08:20 AM
  5. Samsung S4 Mini won't charge
    Last Post: 07-16-2014, 02:47 AM
