Results 1 to 6 of 6
    Default Need to do a *true* factory reset...
    My tablet is rooted. As the heading says, I would like to do a true factory reset, not this "wiping data without wiping data/media" stuff. More like a unlocking the bootloader and watching your life flash before your eyes kind of wipe. How does one do that?
    I did a factory reset from recovery, including wipe data. I even did it from regular settings where it tells you everything will be wiped and it booted into recovery and still left everything is there. Short of just going into my internal SD card folder and just deleting everything, is there another way to do it?
    At this point, I'm just curious. I'm taking all this as a sign that I shouldn't do it.
    Thx.
    Sent from my "no longer 120° or battery guzzling" Sprint Galaxy Nexus, thanks to help from the AC forum
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Need to do a *true* factory reset...
    What recovery are you using?
    TWRP
    Sent from my Nexus 7 using AC Forums mobile app
  4. #4
    Indoler's Avatar
    Banned
    Posts
    Global Posts
    270 Global Posts
    Wipe remotely using free AndroidLost from the Play Store perhaps?
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by gnr_2 View Post
    TWRP
    Can you format the SD card from TWRP? That would be your best bet.
    Good ideas. Will look into both. Thx
  1. LG Health App How to turn off
    By godsidekurt in forum LG G3
    Last Post: 11-21-2016, 08:59 AM
  2. Replies: 1
    Last Post: 03-04-2015, 11:12 PM
  3. File transfer from pc changes from .doc to ..lnk
    Last Post: 07-18-2014, 05:26 PM
  4. How do I access the clipboard on my HTC ة8?
    By AC Question in forum HTC One M8
    Last Post: 07-17-2014, 10:53 PM
  5. How do I make my Internal storage change to to the SD storage??
    By AC Question in forum T-Mobile HTC Sensation
    Last Post: 07-17-2014, 10:17 PM
