Results 1 to 5 of 5
    Default Google play store problem
    Hi.
    I purchased minecraft pe and now I had to uninstall it, cause it was crashing all the time.
    So when I was going to install it, it said I have to pay for it.
    I already paid for the game?
    I first paid and got it on my s3, then without problem on my note 2 too.
    Is there anyway I can fix this?
  2. #2
    STARGATE's Avatar
    Posts
    Global Posts
    9,228 Global Posts
    Carrier
    None
    Default Re: Google play store problem
    There shouldn't be any problems. Email the developer, he might be more helpful about this.
    Sent From Another Galaxy
  3. #3
    Where did you initially purchase the game? If it was on Google Play Store, you should be able to reinstall it, as long as you're using the same Google account. If you had purchased an older version, and the developer came out with a major overhaul of the game, then sometimes that new version is a separate app, and may need to be purchased separately.
    Or did you purchase the game somewhere besides Google Play, like Amazon Appstore or another 3rd party appstore? If so, then you'll have to reinstall from there.
    Thanks for answers, but the problem is solved.
    It suddenly worked again.
  5. #5
    STARGATE's Avatar
    Posts
    Global Posts
    9,228 Global Posts
    Carrier
    None
    Glad it worked out for you.
  1. Problems playing music stored on micro SD card - Galaxy S5
    Last Post: 07-15-2015, 08:59 AM
  2. Viber - Photo indexing problem
    Last Post: 07-22-2014, 11:55 AM
  3. Charging problems with note 10.1 2014 edition
    By thelrose in forum Ask a Question
    Last Post: 07-21-2014, 07:49 AM
  4. Nexus 4 , Network Mobile Problem ...
    By addmiri in forum Ask a Question
    Last Post: 07-20-2014, 04:44 PM
  5. Home: Swipe left to right -> Google Now ?
    By pseudoware in forum LG G3
    Last Post: 07-20-2014, 04:25 PM
