Results 1 to 3 of 3
    Anna W's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Using Android SIM card in iPhone4
    My Nexus 4 got very wet in the recent storms and is not currently working. I have placed it in a bowl of rice and crossed my fingers. Since I need a smart phone I dug out my old iPhone4 (both O2). I have put the SIM card into the iPhone4. I am able to make calls, sent text messages and connect to the internet when using WiFi but when I try to use 3G it does not work. The error message is as follows:
    "Could not activate mobile data network
    You are not subscribed to a mobile date service,"
    I read on a website that it should start working if I sync the phone with iTunes with the new SIM in it. I have tried this and it does not work, same error message. Can anyone offer advice please?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,759 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Using Android SIM card in iPhone4
    Quote Originally Posted by Anna W View Post
    I believe you have a damaged sim card as a result of the water - contact the carrier to have it replaced.
    Anna W likes this.
  3. #3
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Also (and it's too late now), read Wet Phone Putting a wet phone into rice only puts off the inevitable - a non-working phone. Rice absorbs water. (Silica Gel does a much better hob.) But the thing that ruins the phone isn't the water, unless the phone is turned on (IOW, has the battery still in it) when it's wet - it's the impurities in the water that cause shorts and etch the copper off the motherboard and the wires out of their insulation. It's not enough to remove the water, you have to remove the impurities. Even if you could totally dry the phone out in a few minutes, it will eventually fail. How soon? That depends on how impure the water is. Falling into the ocean, or into a muddy pond, is a lot worse than having a glass of drinking water dumped on it, but rain is pretty dirty stuff, It's usually quite acidic, and acids, even weak ones, eventually etch copper completely off the phone. (Sulfuric acid, the most common acid in rain, and copper produce copper sulphate, which doesn't conduct electricity, it just falls off the board and fills the case with little turquoise flakes.) You may look funny doing it, but if you have to carry your phone unprotected in the rain (or use it in the rain), keep it in a zip lock plastic bag. They're pretty waterproof, and sound gets through the plastic easily.
  1. How can I disable volume rocker changing text size in SMS?
    By allanw123 in forum Samsung Galaxy S5
    Last Post: 10-11-2016, 03:46 AM
  2. Android watch with seconds and date?
    By eprisencc in forum Android Wear
    Last Post: 08-04-2014, 10:07 AM
  3. Replies: 3
    Last Post: 07-21-2014, 10:19 AM
  4. 2 moto x phones no emojies showing up in text of one
    By mmk4158 in forum Ask a Question
    Last Post: 07-20-2014, 05:02 PM
  5. Non-Existent SD Card
    By belodion in forum LG G3
    Last Post: 07-20-2014, 04:42 PM
