1. marselisgn3's Avatar
    to be clear. my country doesnt yet support 4g. so no 4g sim card. but id be happier to have the 4g option there. when on settings-more networks-mobile networks-network mode all i get is 3g/2g autoconnect, 3g only,2g only. i want my 4g / lte options to be there even tho they wouldnt work.
    07-21-2014 11:03 AM
  2. B. Diddy's Avatar
    I would guess it has to do with your SIM card. If the network doesn't have 4G, then its SIM won't give that as an option.
  3. B. Diddy's Avatar
    07-21-2014 11:29 AM
  4. dpham00's Avatar
    It depends on the note 3 variant that you have. Some variants are 3g only. If you want a 4GLTE capable Note 3, then you may have to buy one from another area . keep in mind the region lock issue too, it would have to be used on its origin region first. Also, make sure whatever you get has full support for the bands used in your area
    Sent from my Verizon Samsung Galaxy Note 3
    B. Diddy likes this.
    07-21-2014 11:30 AM
  1. Sprint Samsung GS3 won't turn on.
    By Unregistered in forum Ask a Question
    Last Post: 07-21-2014, 02:59 PM
  2. Scratches on Galaxy Note 3
    Last Post: 07-21-2014, 11:21 AM
  3. Is there a tutor on rooting?
    By Kerry89Jones in forum Ask a Question
    Last Post: 07-21-2014, 10:57 AM
