1. Alexander Ramz's Avatar
    I have a nexus 7 2013 that someone broke and bought me a new one. however my data is still on my old device. is there a way to sort of hack into it with my new nexus 7? the usb port and the digitizer is broken on my old one. I didnt know if there was a way to "force" nfc sharing or something to where i could browse the contents of my old nexus with my new one.
    07-21-2014 11:43 AM
  2. raptir's Avatar
    If you had a broken USB port or digitizer, it would be fairly easy, but with both broken I'm not quite sure unfortunately. If you had a bluetooth mouse, keyboard or controller that was already paired to the tablet you might be able to access it, but you need either a working screen or working USB port (for ADB) to get a bluetooth device paired. There are also VNC options but again you need that to have been setup beforehand.
    07-21-2014 12:28 PM
  3. Rukbat's Avatar
    If you have a good relationship with a local independent dealer, you may be able to get him to plug a spare screen into your tab long enough for you to copy off all your data.
    This is a good lesson for everyone reading this thread - ALWAYS have ALL your data backed up to at least 2 different destinations. The odds of both your backup drive and Google failing at the same time are astronomical. (An old computer axiom is that any data not backed up is data you don't need.)
    ShaggyKids likes this.
    07-23-2014 03:52 PM
  1. How turn off text auto reply?
    By Eric Tanner in forum Samsung Galaxy S5
    Last Post: 06-09-2015, 07:35 AM
  2. Cant get access code on my galaxy tab 3
    Last Post: 03-04-2015, 10:32 PM
  3. What parts of phone are IC, MCP and eMMC?
    By RickInHouston in forum Google Nexus 5
    Last Post: 07-21-2014, 03:21 PM
  4. no 4g option on my SM-9005
    By marselisgn3 in forum Samsung Galaxy Note 3
    Last Post: 07-21-2014, 12:54 PM
  5. Where is the 4g option on my Note 3?
    By marselisgn3 in forum General Help and How To
    Last Post: 07-21-2014, 11:30 AM
