1. Ross U's Avatar
    I cannot Sliding Messaging to receive pictures Messages (MMS) to my phone for some reason, and the developer has asked me to get a LogCat for the program. I am not rooted, and have never done this before. I have looked at some how to's but I can't seem to make out what a non rooted user needs to do. Is there anybody who can help?
    07-23-2014 09:37 AM
  2. wizzrah's Avatar
    Hi there.
    You can try the aLogcat app from the play store, or use ADB to get a logcat.
    You would use this command
    adb logcat -v long > something.txt
    Just rename the file at the end.
    This will export whatever adb finds to an external text file on your computer.
    Sent from my One Xl using AC Forums mobile app
    07-23-2014 10:19 AM
  1. Does the kitkat stock messaging app
    Last Post: 09-07-2014, 02:22 AM
  2. for installing watsapp on pc or laptop
    Last Post: 07-23-2014, 09:09 AM
