Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By srkmagnus
    mattlmartin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Need help transferring Data
    Hello all,
    Currently in the process of switching from a HTC one (m7) to a Galaxy S4 active SGH 1357. Does anyone know of a quick easy way to transfer data, i.e. pictures, contacts, most media content and/or other random phone items
    Thanks,
    Matt!
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,764 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Need help transferring Data
    Quote Originally Posted by mattlmartin View Post
    Hello all,
    Thanks,
    Matt!
    I took a look and unfortunately it looks like you can't transfer data from a HTC device to Samsung using Kies. The best way may be to simply connect the HTC Device to a PC and transfer the media to the computer. Connect the Samsung and transfer from PC to the device.
    Be sure to sync everything from the HTC device to Google (system settings > accounts > google). If you have other services, such as Dropbox, do the same. There are other apps to backup call logs and text messages; though, not sure if those will restore to the new device.
    mattlmartin likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you very much for the help! Will do.
  4. #4
    Ludenson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You could also take a look at MyPhoneExplorer...
    Then use it afterwards to manage contacts, notes, media...
    And maybe take local backups.
    It has a lot of features and is absolutely free (donation model).
  5. #5
    Indoler's Avatar
    Banned
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by srkmagnus View Post
    ^This.
    And you could also install a cloud client like Dropbox on both devices and transfer your files via that cloud.
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    As far as contacts, if you enter them as Google contacts (not Phone or Device, which is the default), they're synced for you automatically. Turn on a new phone, enter your gmail account and the contacts sync by default. (You can also sync almost everything else except files that aren't pictures or music that way. Google keeps adding things that sync through the gmail account.)
  1. Data recovery from Samsung s5510
    Last Post: 08-14-2014, 03:22 AM
  2. A lil help please?
    By MrTyC in forum Samsung Galaxy Note 3
    Last Post: 07-29-2014, 10:30 AM
  3. Help my phone stopped working!!!
    By CrysAnn Horst in forum Samsung Galaxy S4
    Last Post: 07-25-2014, 06:11 PM
  4. Replies: 4
    Last Post: 07-25-2014, 04:46 PM
  5. Help! System UI isn't there!
    Last Post: 07-25-2014, 02:54 PM
