Results 1 to 4 of 4
    Lyle DylandY's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default LG G PRO 2 Battery life and its draining toooo fast..
    i just charged my lg g pro 2 a while ago and after 1 hour of stand by use it is only 70% now.
    then i checked on my battery, "mediaserver" is draining my battery,
    here.
    usage on battery 1h 34min
    expected time to use 3h 9min
    media server: 85%
    screen: 5%
    android os: 3%
    android system: 2%
    facebook: 3% [stop]
    ive charged for like 3hours and then expected time to use is around 4hours only? this is not real!
    please help me.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,091 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: LG G PRO 2 Battery life and its draining toooo fast..
    Have you recently accepted an update?
  3. #3
    B. Diddy's Avatar
    Posts
    Global Posts
    78,109 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to Android Central! Do you have an external microSD card inserted? Sometimes a corrupt file on the card can cause the system's Media Scanner to hang up, causing excess battery drainage. Try unmounting the card (in Settings>Storage), removing it, and rebooting. Also insert the SD card into your Windows computer and run chkdsk to scan for bad sectors: http://forums.androidcentral.com/amb...d-sd-card.html
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Golfdriver97 View Post
    when i bought my phone its 4.4.2. and didnt receive any updates.
    Quote Originally Posted by B. Diddy View Post
    oh, i tried to remove all my files on my sd card and it stop draining my battery. so gonna try this up. thank you.
  1. Replies: 22
    Last Post: 05-18-2016, 06:23 PM
  2. Replies: 5
    Last Post: 07-27-2014, 12:53 PM
  3. Battery Replacement for S4
    Last Post: 07-27-2014, 12:55 AM
  4. Galaxy Tab 2 10.1 Battery Issues!!!
    By GalaxyLord in forum Ask a Question
    Last Post: 07-26-2014, 09:51 PM
