1. Lyle DylandY's Avatar
    is there a way or an application that you can suggest to make my phone's battery life be longer?
    im using LG G PRO 2 phone. please help me.
    07-27-2014 08:45 PM
  2. B. Diddy's Avatar
    Check out this guide: http://forums.androidcentral.com/amb...ving-tips.html
    07-27-2014 08:53 PM
  3. Lyle DylandY's Avatar
    thank you sir!
    B. Diddy likes this.
    07-27-2014 09:21 PM
  4. Mooncatt's Avatar
    It looks like your phone is running a Snapdragon processor. You may want to look at https://play.google.com/store/apps/d...snapdragon.app It's Qualcomm's own battery manager for those chips and works by adjusting sync times along with other, more standard, adjustment settings. I just finished the "learning period" and it still may have more to do as it learns where I use Wi-Fi and such, so I can't personally say how good or bad the app is.
    One word of caution is don't fall for the task killer/memory booster/memory optimizer/etc hype. There's many apps that claim increased battery life by cleaning unused apps from memory. That's 180 degrees opposite from how Android is supposed to work and can often reduce battery life. For more info: http://m.androidcentral.com/ram-what...-shouldnt-care
    07-28-2014 04:11 AM
  5. Lyle DylandY's Avatar
    One word of caution is don't fall for the task killer/memory booster/memory optimizer/etc hype. There's many apps that claim increased battery life by cleaning unused apps from memory. That's 180 degrees opposite from how Android is supposed to work and can often reduce battery life. For more info: RAM: What it is, how it's used, and why you shouldn't care | Android Central
    im gonna read and learn about this sir. thank you! [in filipino], salamat!
    07-28-2014 05:01 AM
  6. LGElectronics's Avatar
    Lyle,
    There are a ,lot of little things that might help that will help you prolong your battery life, here's a guide [http://www.wikihow.com/Make-Your-Cell-Phone-Battery-Last-Longer].^IV
    07-28-2014 02:21 PM
  7. Lyle DylandY's Avatar
    Lyle,
    thank you LG. because its my first time to use an LG phone. im a samsung user before but, why not try something new and unique phone? right? with the button at the back? im so loving it.
    07-28-2014 05:29 PM
  8. Lyle DylandY's Avatar
    well, i read, learn, and did what you suggested me to do guys to improve my battery life.
    well, the result is that, my phone is fully charge around 9.20am[100%], then its 9.04am now [the next day] and my battery is now 67%.
    and thats include facebook, sms, messages, camera and downloading apps.
    so what do you think guys? i think it improves ALOT!
    thank you!
    07-28-2014 08:06 PM
  9. B. Diddy's Avatar
    That's pretty darn good!
    07-28-2014 09:13 PM
  10. Lyle DylandY's Avatar
    sir, is there any game/s that you can suggest to be downloaded but not draining battery that fast?
    or games that is offline, because playing when connected to internet drains a lot of battery. so can you suggest any offline games that do not drain too much battery?
    thank you sir!
    07-28-2014 09:27 PM
  11. B. Diddy's Avatar
    Depends on what kinds of games you like.
    07-28-2014 09:41 PM
  12. Lyle DylandY's Avatar
    i can do any games sir, ill just look into any games you suggest. thank you again sir.
    07-28-2014 09:45 PM
  13. B. Diddy's Avatar
    Asphalt 7 & 8
    PewPew
    Grabatron
    Gyro
    Smash Hit
    Major Mayhem
    Giant Boulder of Death
    Monsters Ate My Condo!
    Zen Pinball (one table free)
    Reckless Getaway
    07-28-2014 09:53 PM
  14. Lyle DylandY's Avatar
    Asphalt 7 & 8
    PewPew
    Grabatron
    Gyro
    Smash Hit
    Major Mayhem
    Reckless Getaway
    thank you sir!
    07-28-2014 11:16 PM
  15. Lyle DylandY's Avatar
    sir, about the corrupted memory card.
    ive just checked mine and its ok now.
    just one question, when i put files on my mmc, how should it be?
    1. should remove the mmc from my phone and insert it directly to my laptop? then put files on it.?
    or...
    2. i just plug my phones cable connecting to my laptop then put files on my mmc? w/out removing my mmc from the phone.
    what is more safer sir to do sir? to avoid corrupting files.
    07-29-2014 03:42 AM
  16. B. Diddy's Avatar
    I'm not sure if one way is definitely safer than the other. I'd recommend using the USB connection for transfer, if it works smoothly for you. Just remember that it's best to Copy rather than Move files, because the latter will delete the file at the origin after completing the file transfer. If there was some sort of file corruption during the transfer, then it can be very difficult to recover the original file.
    07-29-2014 11:34 AM
  17. Lyle DylandY's Avatar
    oh thats how it got corrupted. when i bought my mmc, my files from internal storage i tried to move it on my mmc and then thats when it started to drain my battery fast and heats up. so thats why. thank you sir!
    07-29-2014 05:23 PM
  1. How to set up email alias
    By Neal90 in forum Samsung Galaxy S5
    Last Post: 12-19-2015, 09:29 PM
  2. How can I turn off email notifications on my Galaxy S5
    By Unregistered in forum Ask a Question
    Last Post: 03-26-2015, 01:15 PM
  3. Some questions from someone who wants to root
    By InfinityMeep in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 08-04-2014, 07:06 PM
  4. Replies: 6
    Last Post: 08-01-2014, 05:17 AM
  5. Replies: 1
    Last Post: 07-27-2014, 08:24 PM
