1. King Mustard's Avatar
    I ran the script to backup everything on my rooted S5 and when I came to restore age a fresh ROM flash, only around 50% of the apps/app data backup up.
    I was not impressed.
    I don't want to troubleshoot, I've lost all confidence in the app.
    What alternatives do you guys use?
    07-29-2014 01:31 AM
  2. Mooncatt's Avatar
    I've heard a lot of good things about Helium, specifically that you don't need root for it. I haven't personally used it yet because my last phone wasn't compatible (it's a Motorola issue preventing it), and haven't needed to on my current phone.
    07-29-2014 06:14 AM
  3. raptir's Avatar
    I've gone back and forth between Titanium and Helium. Titanium is by far the most reliable backup solution on Android, so i would definitely look into troubleshooting that (and checking that your app data is actually backed up before wiping). Helium isn't bad, but I've had way too many issues with data not restoring to consider it reliable.
    07-29-2014 01:54 PM
  1. Alternative Stylus
    Last Post: 03-30-2015, 01:03 AM
  2. Backup using touch CWM Recovery
    Last Post: 07-28-2014, 01:27 PM
  3. Question about Helium Backup android app ??
    Last Post: 07-28-2014, 12:07 PM
  4. My G3 Review Pros / Cons
    By FaTROBoT97 in forum LG G3
    Last Post: 07-28-2014, 08:23 AM
  5. Samsung Tab Pro 12.2 will not play videos on some websites??
    By hpuser_1977 in forum Ask a Question
    Last Post: 07-27-2014, 08:42 PM
