Results 1 to 2 of 2
    Unhappy Custom Phone Labels in Contacts
    Hi,
    I have a Motorala Milestone and I make extensive use of custom "labels" for phone numbers, email addresses etc and not just use the standard "work", "home", "mobile", "fax" and "other" labels etc to describe the data.
    I'm looking at getting a HTC Desire HD and had a look at the older HTC Desire where it did not look possible to have custom labels. Is this true, and does the new HTC sense have the same limitation?
    Thanks
  2. Thread Author  Thread Author    #2
    Default
    Looks like even if I can't do it on the phone I should be able to do it in online with gmail contacts (not Google contacts).
