1. Sofiboy's Avatar
    I've got a Wiko Highway.
    First I had some problems, I needed to move my cable so my phone could charge. But now nothing works, I've tried different chargers, cleaned the usb port and nothing works.
    But when I connect my phone to my computer I get an error message it causes an failure.
    Is there somthing DIY that I could do to fix this?
    07-30-2014 06:10 AM
  2. Indoler's Avatar
    Sounds like your male (micro) USB connectors were bent or worn out so that proper contact could not be made.
    Chances are you wiggled the USB connector(s) so much so often to make contact that now the female side – in your phone – has been bent so much out of shape that contact – = charging – cannot be established at all anymore.
    If so then there's nothing you can DIY to improve the situation. The phone would need to be repaired by pros.
    Sofiboy likes this.
    07-30-2014 06:43 AM
  3. Mooncatt's Avatar
    It also could have been the wires inside the cable going bad (pretty common problem). I don't know if I'd go so far as to say your wiggling bent the port connectors, though. I've had some ports get fairly loose over time but they still worked. My first thought is the excess wiggling just finished off the break in one or more of the internal wires.
    I know you said you tried different chargers, but you didn't say if you tried different cables with them. If not, try a new one and see how that works. If it does, there's places like Mono Price and My Cable Mart online that sell them dirt cheap. You may want to buy some spares and stock up. In my experience, there doesn't seem to be much difference in durability between those cheap cables and the expensive ones you see in stores. At least not worth the price difference.
    Sofiboy likes this.
    07-30-2014 09:38 AM
  4. Sofiboy's Avatar
    Thanks, but I've tried it but it didn't work. I'll just give my phone to pros tomorrow
    07-30-2014 02:09 PM
  5. Rukbat's Avatar
    There's one definitive problem when the phone only charges if you wiggle the cable - the microUSB connector in the phone has become disconnected from the board it's soldered to. (The same thing happens in laptops.) When you wiggle the cable you move the connector, so the badly soldered pin makes contact with the board. The problem is that each time you make and break a contact you make a spark. Eventually, that spark carbonizes the board, so that in addition to resoldering the pin, you need a new board. If the particular phone model has the connector soldered to a little "carrier" board, it's not to expensive to replace (some connectors already soldered to the carrier board are less than $5), but if the connector is soldered directly to the motherboard, you need a new motherboard, and that can get very expensive.
    So at the first sign of "it won't charge unless I wiggle the cable", get it fixed, phone or laptop. It's a lot cheaper to pay to have a pin soldered (a good shop will remove the connector, clean the board and resolder all the pins) than to pay for a new motherboard.
    07-30-2014 04:12 PM
  6. Indoler's Avatar
    In my book 'dirt cheap' equals low quality. Hence the odds at wiring breaking or connectors bending increase a lot, imo. I don't think I would want to run that risk a second time.
    07-30-2014 05:53 PM
  7. Mooncatt's Avatar
    As I said later in my post, that has been my experience. When I got my first smartphone and made the jump from traditional to USB charging, I started having cables go bad right and left. Sometimes in a month, and lucky if I got 6 months use out of one. I tried name brand, "heavy duty", and generic. They all seemed to fail at about the same rate, and always right behind the male micro-USB plug. So I said the heck with it and started buying them from My Cable Mart in small bulk batches (for quantity discounts). Even if they didn't last as long, it was still cheaper in the long run. Oddly enough, it was one of those cheapies that lasted the longest of any cable I've used, at about a year's life.
    07-30-2014 06:42 PM
  8. andrew pearson3's Avatar
    My phone would charge either with any cable % kept going down. had it charge all day and stayed at 16%. All i had to do was take out the battery and every thing was fine.
    05-18-2017 04:25 AM
  1. LG e 405 Android Phone Screen black
    Last Post: 03-30-2015, 01:11 AM
  2. My Samsung Samsung S3 (White) won't switch on.
    Last Post: 07-30-2014, 05:30 AM
  3. Trying to put 4.4.2 on my phone. need help.
    By backwoodswayne in forum AT&T Samsung Galaxy S4
    Last Post: 07-30-2014, 05:25 AM
  4. Unlocking Phone
    By kanesmith41 in forum Sprint Galaxy Note 2
    Last Post: 07-30-2014, 04:40 AM
  5. Bluetooth headset to phone to audio ampifier
    By bosjef in forum Ask a Question
    Last Post: 07-30-2014, 04:06 AM
