1. numberpro's Avatar
    Hey guys, I am done for now the the Palm Pre. The Sprint Evo 4g looks good for me. So I have a simple question.
    The retailers like amazon have good deals, but it always says with a new 2 year contract. How do existing customers get that price, without changing plans? What is the activation process? Thanks!
    10-28-2010 12:52 AM
  2. Kevin OQuinn's Avatar
    if you're ready for an upgrade it'll give you that price when you go through the check out process. as for activation you call and activate the phone when it gets to you in the mail.
    10-28-2010 01:55 AM
  3. numberpro's Avatar
    Ok, I went through the checkout process, but it says the price is for new customers only. But I already have a simply everything plan on my palm pre. So what happens when I buy with amazon as a new customer? I don't want to activate two plans.
    The only reason I want to buy from amazon or bestbuy is to avoid the mail in rebate under sprint. Thanks!
    10-28-2010 05:11 PM
  4. milominderbinde's Avatar
    If it says new customers only, I know of no way around that. You would end up with two plans nearly doubling your price.
    But first, Welcome!
    As you are getting ready for the jump here are a couple of resources:
    Palm webOS Homebrewer's Guide to Android
    Getting Started with Android - Tips and Tricks
    If you are a Homebrewer with patches, here's the guide:
    webOS Patches that Are Standard Android Features
    Basically every app we wished for and our favorite patched are already here waiting for you. Palm may not listen to our pleas to add these features but Android does.
    You are in for an amazing ride. Have fun!
    10-28-2010 05:54 PM
  5. myswagsblue's Avatar
    if your uprgrading through sprint and doing on amazon the price you see is what youll pay for the phone most likely and call to activate like has been said
    also make sure your in the upgrade section if you choose to do it on amazon.
    id recommend ebay but im guessing those listed are only new customers unless you come upon a upgrade listing
    10-28-2010 10:38 PM
