1. Lyle DylandY's Avatar
    hello guys, good afternoon [1:54pm here], i would like to ask you about icons and themes.
    i have a phone, lg g pro 2, and just want to ask, is it possible to change my icons that look likes the lg g3 without using any launchers like nova launcher?
    thank you!
    07-31-2014 12:56 AM
  2. raptir's Avatar
    Well, you are already running a launcher, just the stock LG launcher. Android gives no preference to the stock launcher over launchers installed from the play store. Is there a particular reason you're so resistant to using an alternative launcher?
    Regardless, this theme should work with the stock LG launcher according to the description:
    https://play.google.com/store/apps/d...theme.rocketg3
    07-31-2014 09:00 AM
  3. Lyle DylandY's Avatar
    well, i want my lg launcher but i dont like the icons, i want to make those icons look like the lg g3 without installing launchers,
    07-31-2014 07:23 PM
  1. First Android and it won't lock
    By Fisherman559 in forum Samsung Galaxy S5
    Last Post: 07-31-2014, 12:59 AM
  2. Replies: 7
    Last Post: 07-30-2014, 11:10 PM
  3. What is this Notification icon?
    By DavidJ726 in forum HTC One M8
    Last Post: 07-30-2014, 10:42 PM
  4. AT&T Samsung Galaxy S III Version 4.3 text messaging icon
    Last Post: 07-30-2014, 10:31 PM
  5. Issues with Sound/No Warranty
    Last Post: 07-30-2014, 08:36 PM
