Any devices that you can root without looseing warrenty? just curios ?
(besides) moto x dev edition?
I was under the impression that the warranty was still void, it was just harder to brick those devices.
Oh ok i just think i heard somewhere maybe xda? that you can root it without looseing warrenty ?
Sorry, your post got lost in the shuffle of my other notifications that night.
I might be wrong, but that is why (the last I knew) the Knox counter was unchangeable.
LOL i know that you can unlock bootloader without looseing warrenty? so i guess that ment root as well?
Anyway Dont worry but how have a little question .
How do i update my slimkat rom? it says 4.4.4 is out but i dont know how to update?
I have always understood that you root, you voided your warranty.
As far as I know, that is the most up to date version of SlimKat. They are a little slower than most other Dev's for updating ROMs, but when they do, they are usually pretty solid. I just got in the habit of checking on their website. To update, you would download, and flash in recovery, the same way you loaded the ROM initially.
My update came up in slimcenter
But i think i killed my TWRP since i flashed stock recovery to see how it looked and it was boring so i open rashr and got TWRP again.
And now it fails every flash ;(
Since i clear dalvik and tap install i select 4.4.4 slim and it just sats "Failed" ??
Try again, but instead, download from the site, and flash through TWRP.
Signed, an M8, Liquidsmooth, and the AC Forums App
Oh cr@p it blow up!!!!
JK Anyway so do i just clear dalvik cashe and tap install? after i redownloaded it from the web side???
Dalvik and system cache. Reset only when you change ROMs or get a major update.
And do i need to reflash Gapps? to 4.4.4?
Nope.
Nevermind it worked 100%
Cool
Yeah right? LOL
BTW do you have any apple products just curios ?
A 2nd gen iPod Nano.
Lol i remember when i had one until i got shot in the leg and it broke. so i dont have any apple products now
Shot in the leg? What happened?
