Results 1 to 3 of 3
    Salim90's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Lenovo S820 upgrade problem
    i have lenovo s820(android version 4.2.1),like 3 or 2 days ago i checked system update to check if there is any update available for my phone and luckily a upgrade for android 4.4 showed but i decided to download it later and after some days when i checked again it disappeared, i tried checking system update again again but failed all the time, i tried rebooting my device many times also did the checking method but nothing worked. help !
    check this link - https://news.google.co.in/news/rtc?n...2ae8a074fa22d5
  2. Best Answer
    Posts
    Global Posts
    4 Global Posts
    Solved.
    Delete this thread.
  3. Thread Author  Thread Author    #2
    Salim90's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Lenovo S820 upgrade problem
    Solved.
    Delete this thread.
  4. #3
    sachn dedhia's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Upgrade Android 4.4.4
