1. Android354's Avatar
    Because i broke my charger and im using my phone's Charger And it takes long time to charge and while im playing its reducing any solutions?
    08-02-2014 03:21 AM
  2. Rhyalus's Avatar
    You need to assure two things...
    1) The output voltage should match exactly what you have on your original charger. Usually 5v.
    2) The output current must be the same OR greater than you have on your original charger. So if it is a 1A rating, meet or exceed that.
    Otherwise, as long as the plug fits ... You are good to go.
    R
  3. elementeyas's Avatar
    Universal Chargers are always worse than the Original Chargers
    I suggest that you go and buy an Original charger , they perform better and are safer
    08-02-2014 05:23 AM
  4. FishenFool's Avatar
    That's crap. It depends on the output specs of the charger being used.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
    Rhyalus likes this.
    08-02-2014 05:36 AM
  5. Rhyalus's Avatar
    R
    08-02-2014 05:44 AM
  6. dpham00's Avatar
    You would also want a quality charger. A bad charger could cause many issues, including in extreme cases, death.
    Sent from my Verizon Samsung Galaxy Note 3
    08-02-2014 06:42 AM
  7. Rhyalus's Avatar
    Quoted for most dramatic post of the day. :-)
    I would just add that looking at customer reviews on amazon would suffice to make sure you are getting a charger that doesn't fail often, etc.
    I would not buy one on a street corner...
    R
    08-02-2014 06:59 AM
  8. Android354's Avatar
    Thanks for answering guys.
    08-02-2014 07:50 AM
  1. GS3 Shuts Down Due to Dead Battery but Battery is NOT Dead!
    By wowzem in forum Sprint Galaxy S III
    Last Post: 02-11-2015, 08:47 AM
  2. crappy phone quality using bluetooth on car phone
    By jyinger in forum Samsung Galaxy S4 Google Edition
    Last Post: 08-03-2014, 01:50 AM
  3. Battery status it show 1%
    By jj_jayanti in forum HTC One M7
    Last Post: 08-02-2014, 02:55 AM
  4. Screen Using 61% of my battery
    By Kevin Deuel in forum Ask a Question
    Last Post: 08-01-2014, 11:20 PM
  5. Light is on, but not charging when plugged in
    By Jason Eddy1 in forum Ask a Question
    Last Post: 08-01-2014, 09:55 PM
