1. Bayarea13's Avatar
    I currently use a cassette adapter however it's starting to deteriorate and I'd like something better than a cassette adapter cause I heard the music quality isn't as good with cassette adapters. Also I prefer something that is small so I can put it somewhere hidden when I leave my car cause I work at a place where car break ins are frequent.
    08-04-2014 11:04 PM
  2. B. Diddy's Avatar
    Let's try to consolidate your multiple posts--see responses in this thread: http://forums.androidcentral.com/gen...r-old-suv.html
    08-04-2014 11:11 PM
  3. Indoler's Avatar
    If sound quality was the only thing at stake here I would say earphones fed by your smartphone with the appropriate apps and music installed, assuming it is on a charger. Because you take your phone out of the car with you anyway when you park it, right? So there's nothing to burgle (car burglars know twice as many hiding places in your car as you do... but empty phone holders speak volumes to them). However, the earphones' wire will be a nuisance after the first few minutes of use. And there ain't no decent wireless ones available yet, afaik.
    That said I definitely do NOT recommend this 'solution' to your problem because it also makes you a dangerous traffic hazard when traffic sounds around your car are inaudible to you, the driver!
    08-05-2014 12:03 AM
  1. Replies: 10
    Last Post: 09-22-2014, 12:56 PM
  2. Strange images & album have appeared in my X
    By manhattan123 in forum Moto X (2013)
    Last Post: 08-09-2014, 05:08 AM
  3. Prism still won't connect to wifi
    By Felicity Green Moore in forum Ask a Question
    Last Post: 08-04-2014, 09:16 PM
  4. I have the unlock code! But dnt know what to do
    Last Post: 08-04-2014, 08:26 PM
