Results 1 to 5 of 5
    Default Can GPS receiver/logger be connected via USB to android tablet?
    I have a small GPS receiver / logger based on the MTK chipset, similar to products such as iBlue, Holux, Qstarz and Photomate (I have the Photomate 887). These have USB interface to allow the device to stream real-time GPS coordinates through the USB or bluetooth to a PC (or compatible camera).
    Is it at all possible for an Android tablet with USB port to receive GPS data from these devices and plot your position on (some) available mapping program - to essentially turn the tablet into the equivalent of a Garmin or Tomtom (etc) GPS trip navigator?
    Would an android app do the actual "talking" directly through the USB to the receiver, or is that something that the OS itself would (or must) do?
    A second question is - are there any android tablets with actual GPS receivers built into them?
    A third question - for an android tablet that doesn't have internal bluetooth, can bluetooth be added via USB adapter?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Can GPS receiver/logger be connected via USB to android tablet?
    1. No, I highly doubt you can plug and play the gps feature. You'll likely need to develop an app to read the receiver data.
    2. Most tablets have gps built in. You'll need a data connection for the tablet to update the map.
    3. I don't think this will work, similar to the gps question above. It doesn't have the drivers to run bluetooth.
    There are many small tablets (7", 8", etc) that retail for less than $100 that don't have internal GPS or bluetooth.
    But they almost always have mini-usb ports. Some even have HDMI out (to connect to TV or monitor).
  4. #4
    Indoler's Avatar
    Banned
    Posts
    Global Posts
    270 Global Posts
    Quote Originally Posted by srkmagnus View Post
    ^This.
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by a278598 View Post
    Ah, OK. Unfortunately there is not a way (that I've come across) to enable GPS from another device through the tablet. There's a lot of technicalities involved that don't allow it to work without some hardware changes or writing of an App, which may be difficult to do.
  1. New to Android Central
    By Mathusalemrex in forum Introductions
    Last Post: 08-13-2014, 11:36 PM
  2. Unable to use Google Play Services
    Last Post: 08-09-2014, 10:35 AM
  3. Replies: 0
    Last Post: 08-09-2014, 08:51 AM
  4. Replies: 0
    Last Post: 08-09-2014, 08:50 AM
  5. N7105 (note 2 lte) can't browse web via browsers in China
    Last Post: 08-09-2014, 06:59 AM
