1. radicchio's Avatar
    I have seen some screen shots of an application drawer with tabs running down the right side of the screen for various categories (i.e., tools, web, games, etc.). The tabs look like the index dividers in a notebook. Can anyone tell me if this is a feature of a particular launcher or it's a separate app? Is it available for stock phones, without root? I tried to find a picture to show you what I'm talking about, but, of course, now I can't find it anywhere.
    08-09-2014 12:44 PM
  2. srkmagnus's Avatar
    Nova Launcher (Prime) had that feature. Apex may also have it, so check both those out. For Nova, you need Prime and it's located under the app drawer settings (Nova settings - app drawer). You can set tabs or folders.
    Let me know if you have further questions.
    08-09-2014 05:48 PM
  3. radicchio's Avatar
    Thank you! I was hoping someone would know and respond to this question. I looked at quite a few Nova screenshots, but couldn't find exactly what I was looking for---yet I thought I remembered it was Nova that could do it. I wasn't sure if it was a feature that required rooting, though.
    I have used Smart Launcher for some time and have been concerned that a more complex launcher like Nova would be too complicated or consume too many resources, but I am beginning to learn more about Nova and would like to give it a try. I also hesitated because I tend to like a rather plain, minimalistic home screen---but I've seen that you can use Nova to make the more subdued home screens, as well.
    Thanks again for the information!
    08-09-2014 07:12 PM
  4. radicchio's Avatar
    I finally found a Youtube video about Nova's app drawer and, while it is divided into different groups, the layout isn't exactly what I was hoping to find. The Nova app drawer has the different categories listed horizontallly across the top of the screen. What I saw was an app drawer that had the categories on tabs that ran vertically down the right side of the screen. Basically, it looked just like the pictured index dividers in the following link, except each tab was a bit bigger---and instead of A-B-C, of course, there were different categories listed..
    http://www.amazon.com/Cardinal-Produ...cUvbUpU3822417
    The Nova Launcher tabs would certainly work, and I appreciate your mentioning them, but I would really like to find the one with the vertical tabs, if possible. Anyone know what that might be?
    08-10-2014 02:03 PM
  5. radicchio's Avatar
    I finally found a picture similar to what I'm looking for. It's like the "Bookmarks" for Themer on the page below. The only difference is that I was looking for something with this look that would only be on one screen and the tabs would be divided into different categories to divide the apps into.
    The Best Themer Themes to Refresh and Customize Your Android Phone
    Since no one has responded yet, though, I'm guessing no one is familiar with what I'm looking for. (Or maybe I just imagined I saw it?).
    08-12-2014 05:59 PM
  1. Application access rights
    By IBMJunkman in forum Samsung Galaxy S5
    Last Post: 08-09-2014, 12:00 PM
  2. Samsung tab 3
    By Unregistered in forum Ask a Question
    Last Post: 08-09-2014, 05:38 AM
  3. samsung galaxy tab 2 10.1
    Last Post: 08-08-2014, 03:40 PM
  4. Finding the serial number a verizon galaxy note 10 tab???
    By robster8719 in forum Ask a Question
    Last Post: 08-08-2014, 12:00 PM
