Yes, I'm talking about the OG Droid that had a crappy physical keyboard. I can get one for dirt cheap and it'll be like owning a piece of history. Anyway to activate it on Verizon prepaid? There's no sim slot because its not an LTE phone.
You'd be much better off going with Page Plus. It's the largest Verizon MVNO and I've used them for years. They're cheaper than Verizon and you get the same service. But if you're already on the Allset plan, yes you can use it.
