Results 1 to 3 of 3
    CannedBullets's Avatar
    Posts
    Global Posts
    289 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Is it possible to use Verizon prepaid on the original Motorola Droid?
    Yes, I'm talking about the OG Droid that had a crappy physical keyboard. I can get one for dirt cheap and it'll be like owning a piece of history. Anyway to activate it on Verizon prepaid? There's no sim slot because its not an LTE phone.
  2. #2
    fatclue_98's Avatar
    Posts
    Global Posts
    5,068 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Is it possible to use Verizon prepaid on the original Motorola Droid?
    You'd be much better off going with Page Plus. It's the largest Verizon MVNO and I've used them for years. They're cheaper than Verizon and you get the same service. But if you're already on the Allset plan, yes you can use it.
    Posts
    Global Posts
    289 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by fatclue_98 View Post
    Yeah i think I'll go with them instead. Not sure what the Allset plan is so I'm probably not on that. So activation with Page Plus is easy?
  1. Replies: 3
    Last Post: 08-19-2014, 02:09 PM
  2. New to Moto X
    Last Post: 08-10-2014, 10:10 AM
  3. Replies: 1
    Last Post: 08-09-2014, 10:51 PM
  4. Disable Emergency Alerts for Verizon
    Last Post: 08-09-2014, 09:36 PM
  5. can I reinstall contact list on any brand of phone
    Last Post: 08-09-2014, 08:41 PM
