1. Jason Newstedt's Avatar
    Beep beep...beep beep...beep beep...
    This is what I hear all night as I charge my Samsung S4 that was recently updated to "kitkat."
    I plug the phone in to charge and the screen keeps coming on as if I just plugged it in, and making the beeping sound.
    It won't stop. The problem started right after the kitkat update.
    The screen flashes on every 15 seconds.
    I have used the Kies software to make sure everything is up to date.
    I have taken everything off of my phone and done a "master" (factory) reset.
    Nothing worked to get it charge without sounding like a stoned robot.
    Make it stop. Someone is going to die if it continues.
    08-12-2014 12:39 AM
  2. Indoler's Avatar
    Must be aliens trying to attract your attention.
    08-12-2014 04:16 AM
  3. ShaggyKids's Avatar
    Is it possible an app is beeping? Maybe you need a new battery? Try plugging it into a different charger and see if it does the same thing?
    08-12-2014 07:43 AM
  4. Jason Newstedt's Avatar
    Maybe it's because of the update?
    That's what I'm thinking. I would love to roll back to my earlier version and end this nightmare.
    08-12-2014 10:55 AM
  1. Replies: 74
    Last Post: 11-15-2016, 04:29 AM
  2. Qi charging pad that does not beep?
    By tonybessette in forum Samsung Galaxy S5
    Last Post: 09-12-2014, 06:18 PM
  3. Verizon. g3 annoying beep on call connect
    By doggy2965 in forum LG G3
    Last Post: 08-08-2014, 12:57 PM
  4. random beeping noise
    Last Post: 08-03-2014, 02:01 PM
  5. Constant Beeping / Not charging
    Last Post: 07-20-2014, 09:00 PM
